Maarten den Hartog
#1 Posted : Friday, September 7, 2007 1:56:52 AM(UTC)
Maarten den Hartog
Was thanked: 4 time(s) in 2 post(s)
In the bottom of the tool window a quickly change of the display shading can be done. This changes only the static shade mode. When dynamicly rotating the object the preset is taken from "View -> Shade options". Very often this is a different mode and gives an unpleasant change from wireframe to phong or v.v.
Can the display shade setting in the toolbox both set the static display as the dynamic display?
Maarten
