Martin,
I currently use CamBam for 2.5D cutting work (still learning how to use the 3D abilities of CamBam as curve is a bit steep). I use BobCAD/CAM for complex 2.5D  (angled surfaces and surfaces where the bottom of the pocket IS the important part). I am currently working on learning CamBam more and looking at adding Aspire to the knowledge base as I really like the layout and tool set up of Aspire over CamBam (though CamBam is much better at making clean code then BobCAD/CAM [wish I had never bought it, but a lesson learned]).
Back to the fill/surfacing. pocket number three from the end with the small pockets will not allow me to surface it. I have checked direction and that does not seem to be the problem and also check all the lines and they are the correct measure for full connection. Also have surfaces touching all the lines. So any help for what I am missing would be greatly appreciated.
If any of you folks are interested in what this goes to, it is half of a professional grade 12 hole chromatic harmonica comb. once I get some cut will post a link on my website (soon to go live, pain in the backside). I will have various items that I have done design and reverse engineering of on there and from now on VC will be the program that the design work is done in.
I just have to figure out how to build the libraries of all the parts I use often (varying M2 bolts, M1.6, M1.4; gaskets, valves, springs, reed forms). I really like how well the program lets me build quickly and accurately the parts I need for projects. makes setting up for cutting, shaping much easier and the 2D let's me send designs to some of my mentors for them to give feed back and show where I might be doing something the hard way or have found a solution to a problem in a different fashion.
Thanks for building this program guys/gals and thanks even more for making it affordable for us small business's.
Michael Marino, DC
Owner: Free Reed Foolery.
Edited to add update image for ease of seeing the problem wiring section.
 270 Pro Combstiched.vc3
(125kb) downloaded 6 time(s).You cannot view/download attachments. Try to login or register.
