I have a part I drafted that is scaled to 3/8"=1". How do I add a title box without messing up the scaling of the part?
Hi You can insert title block from the symbols and scale as needed Regards Jason
Jason, Thanks for the reply. Could you elaborate on symbols? Not sure what that is and how to insert a title block from that. Very new to cad.
Thanks: 39 times Was thanked: 30 time(s) in 23 post(s)
Hello North
Not sure to understand what do you want to do, if i get well, you need a title block to make a description of your part, so you need to fit your part inside a drawing?
Not sure why do you need to scale your model, if what you want is to make a drawing, with scaled draws, notes, dimensions, title block and so, then Model to Sheet (MTS) is your answer.
check this video and see if it is what you are looking for (old one but helpful)
http://www.csi-concepts.com/Dem.../ModeltoSheetOnePart.mov more videos here
http://www.csi-concepts.com/demos.htm Luis G
