NorthridgeFab
#1 Posted : Thursday, February 14, 2013 9:04:24 PM(UTC)
NorthridgeFab
I have a part I drafted that is scaled to 3/8"=1". How do I add a title box without messing up the scaling of the part?
#2 Posted : Friday, February 15, 2013 5:30:11 PM(UTC)
Hi
You can insert title block from the symbols and scale as needed
NorthridgeFab
#3 Posted : Friday, February 15, 2013 10:00:50 PM(UTC)
NorthridgeFab
Jason,
Thanks for the reply. Could you elaborate on symbols? Not sure what that is and how to insert a title block from that. Very new to cad.
NorthridgeFab
#4 Posted : Thursday, February 21, 2013 8:46:56 AM(UTC)
NorthridgeFab
Anyone????
#5 Posted : Thursday, February 21, 2013 9:52:28 AM(UTC)
Mexico
Hello North
Not sure to understand what do you want to do, if i get well, you need a title block to make a description of your part, so you need to fit your part inside a drawing?
Not sure why do you need to scale your model, if what you want is to make a drawing, with scaled draws, notes, dimensions, title block and so, then Model to Sheet (MTS) is your answer.
check this video and see if it is what you are looking for (old one but helpful)
http://www.csi-concepts.com/Dem.../ModeltoSheetOnePart.mov
more videos here
http://www.csi-concepts.com/demos.htm
MacOSX Sequoia 15.7.7
