SteveB
#1 Posted : Monday, April 23, 2012 1:42:17 PM(UTC)
SteveB
I am trying to put engraved text onto the outside of a solid cylinder.
Nothing I have found will bend the text then apply it to the surface.
Is there a tutorial available?
Using ViaCadpro v7.
rockyroad_us
#2 Posted : Tuesday, April 24, 2012 9:07:47 AM(UTC)
rockyroad_us
Don't you have the command text along curve. I would draw a circle and put the text which goes along the circle then extrude and subtract.
SteveB
#3 Posted : Tuesday, April 24, 2012 10:12:34 AM(UTC)
SteveB
Yes, VCP has a text along a curve function.
Thanks for the tip:). However, it doesn't quite operate correctly. I have attached a ViacaPro V7 file to show the results so far.
The text Font is not correct (Times New Roman) and cannot be moved to a different location (or re-sized) on the curved surface
Text_ON_Cylinder.vcp (22kb) downloaded 10 time(s).
#4 Posted : Tuesday, April 24, 2012 10:29:30 AM(UTC)
I made a video showing a possible solution.
http://www.csi-concepts.com/Demo/videos/textBend.mp4
SteveB
#5 Posted : Tuesday, April 24, 2012 10:38:07 AM(UTC)
SteveB
Thanks for the tip! :)
However, the font (times new roman) cannot be moved up the cylinder where it needs to be for engraving.
Also, once the VCP file is exported to .dxf or .stl, the resultant 3d surface has lost the text. :confused:
Could not attach files this time--upload error...
SteveB
#6 Posted : Tuesday, April 24, 2012 10:50:03 AM(UTC)
SteveB
Thanks, Tim!!
I tried your method but did not fully succeed.
Some of the characters in the text string would not extrude. See the exclamation points and the letter "r" in the attached file for an example.
The font was Vani, but other fonts had similar problems.
Is it possible that this font issue is related to my graphics card?
Running quad core AMD Phenom II, 2GB ram main memory, >= 2 GHz cpu speed, onboard video card, and Windows 7 32 bit home premium.
FontExtrudeProblem.vcp (696kb) downloaded 7 time(s).
rockyroad_us
#7 Posted : Tuesday, April 24, 2012 10:53:10 AM(UTC)
rockyroad_us
I see what you mean. The extrude doesn't work with the text along curve. Tim doesn't the text get stretch with your approach in the video taking into account the perimeter of the curve.
#8 Posted : Tuesday, April 24, 2012 10:59:36 AM(UTC)
Yes. If the bounding volume length relative to the arc length is:
greater--bent solid is compressed
less--bent solid is expanded
equal--little to no compression or expansion
Jean-Francois Jacques
#9 Posted : Tuesday, April 24, 2012 12:34:33 PM(UTC)
Canada
Very good Tim, unfortunately we cannot save your QuickTime movie!
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
SteveB
#10 Posted : Tuesday, April 24, 2012 11:05:11 PM(UTC)
SteveB
I was able to save it on my PC, using the popup window to select either to play the file using Windows Media Player or "save file" to my "Downloads" directory.
SteveB
#11 Posted : Wednesday, April 25, 2012 1:24:09 AM(UTC)
SteveB
Thanks, Tim!!
I will try your method.:)
Tim, I have not been able to complete all the steps properly as shown in your video.
The extrusion of the font text always drops out some of the characters (like punctuation, for instance).
See attached file for an example of what extruded text looks like.The letter "r" and the exclamation points will not extrude.
The font used was "vani", but similar problems problem occur on most other fonts also:confused:
FontExtrudeProblem.vcp (696kb) downloaded 5 time(s).
#12 Posted : Wednesday, April 25, 2012 8:10:18 AM(UTC)
Canada
We was able to save on Mac a QuickTime movie via the small arrow at the lower right corner. But now, for some reasons it's impossible. Maybe is due of the Tim settings'.
#13 Posted : Wednesday, April 25, 2012 8:24:18 AM(UTC)
Canada
What do you expect? .....this solution...
Jean-Francois Jacques attached the following image(s):
Screen shot 2012-04-25 .jpg (34kb) downloaded 6 time(s).
#14 Posted : Wednesday, April 25, 2012 8:35:35 AM(UTC)
Canada
Look my video for your font!!! Unfortunately, I don't know the logic behind my solution. Tim...what is wrong??
http://screencast.com/t/h9NZpodTm
#15 Posted : Thursday, April 26, 2012 2:48:12 PM(UTC)
Months ago, this is what I was attempting to do when attaching text to a compound surface that is the bow of a ship. I figured out (eventually, the hard way) that I couldn't get text onto the surface (easily?), so I thickened the surface. ( Then, I made text and extruded it, then split it from the solid of the ship's shell plating. The text had some excess size so I could move it and a guide surface onto the shell plating and split it. This gave a "raised" surface effect. However, it was problematic, and I eventually gave up when a co-worker commented that for labor costs, today, most ships' names are just painted on the surface, and no expensive bead welding is raised to be painted.
IIRC, later I "projected" text to a surface and treated it as a banner. But, IIRC, surfaces I was dealing with had too many intervening curves embedded, and the spread of letters always landed inconveniently on a curve. So, making extruded text become split was painful because the intervening curves did strange and wholly undesired things to the text. Now that I've been experimenting with curve and surface quality settings, in Freeship, I may have removed unwanted curves that would otherwise appear after turning the mesh into a surface. Now, I just use much finer and appropriately-spaced stations, and I hope I'll get letters of the right spacing on those surfaces.
Still, it would be nice if one could stencil text onto a surface (whereby VCP/Shark would make a "text background base" that is not ravaged by embedded mesh or surface facet curves, and that base follow the models' curvature, so the text is smooth...), with the intent to have 'banners" like on model trains, planes, ships, cars, etc, set a reasonable amount of curvature lifting from the surface, and, and, AND, be able to rename it easily, in the event of spelling error or renaming airplanes or ships to make multiples of a same class or family/production line for display purposes.
Part of the problems I had, as others pointed out, involved punctuation and certain letters and certain fonts failing to project or extrude.
