Import/Export
Importing Adobe Illustrator into VCP V7 (#4517)
Simple text imports from .ai are OK, but more complex images crash VCP pro V7.
Attached file exhibits the crash problem.:confused:
I am importing from CorelDraw as .ai ver. 8
**** sorry, cannot attach .ai type files on this forum ****
Now, attempting to upload the file as .zip!!!;)
Newest01 Vector Pattern 362.zip
(347kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
... you could zip it - then upload
Thanks: 35 times Was thanked: 15 time(s) in 13 post(s)
illustrator to viacad and viacad to illustrator splines are jumbled messes to begin with. Illustrator to dxf, vc to dxf works well...but each translation (vc -> illustrator with dxf/dwg files) adds control points to splines. after a few times they become kinked.
I use both in tandom and find reducing spline points on each opening/ edit is key.
If the attachment works, this is opening your file in Illustrator, exporting as dxf, then importing in vcpro. No crash, nothing sluggish.
why uploading vcp files is a challenge I will not understand.
aitodwgtovc.vcp
(279kb) downloaded 6 time(s). Newest01 Vector Pattern 362.zip
(558kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Tim - can .ai files be added to the allowed upload formats please ? (I thought it was already - it's a bit strange)
Import/Export
