bug on objects geometry reference? (#3827)
Thanks: 39 times Was thanked: 30 time(s) in 23 post(s)
hello, something it is going wrong with referenced geometry on grouped objects, i been experiencing this on build fx 967-mac, normally this happen when a grouped object is moved whit the gripper handles an the undo command after that, please see the picture attached,
I tried to upload a video and i could't, so please check it a this link for it:
http://www.miditec.com.mx/sharkvids/badgeoreference.mov anyone else has experienced the same?
Luis G.
(40kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
I can't seem to get the link to the movie to work. Tim
These is certainly a problem with the gripper when used to make a copy. In 936 if you copy using the gripper and enter a distance in the box the copy disappears [ATTACH]3914[/ATTACH]
In 969 the effect is weirder...
[ATTACH]3915[/ATTACH]
Gripper copy problem.mov
(1,735kb) downloaded 0 time(s). Gripper copy problem-2.mov
(369kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
This is also a problem in Viacad 2d/3d V8 beta.
Originally Posted by: Tim Olson I can't seem to get the link to the movie to work. Tim
Link is working fine for me, anyone else can't see the video?
Gripper copy bug fixed in next upload. Tim
Thanks: 140 times Was thanked: 124 time(s) in 84 post(s)
Probably this is unrelated, but in VCP 7, when I import some geometry, it just vanishes. It is restored and persists (behaves correctly) if I turn off then back on that respective geometry's layer. I am not sure if the code is related, and I am not sure if it is related to using FreeShip 3.22/3.23+.
