NorthridgeFab
#1 Posted : Tuesday, September 17, 2013 11:10:35 AM(UTC)
NorthridgeFab
When I open this DXF file in VC is does not show correctly. When opening in Draftsight, it shows correctly. VC is the white background.
NorthridgeFab attached the following image(s):
blowlamp
#2 Posted : Tuesday, September 17, 2013 11:22:09 AM(UTC)
blowlamp
Can you post the DXF file for us to look at?
Martin.
rockyroad_us
#3 Posted : Tuesday, September 17, 2013 11:22:29 AM(UTC)
rockyroad_us
I think your custom resolution is wrong. Try preferences and check your custom resolution. I have mines at super fine and curve angle 2.0
NorthridgeFab
#4 Posted : Tuesday, September 17, 2013 1:08:23 PM(UTC)
NorthridgeFab
Adjusting the resolution did not fix it.
How do I post the DXF?
#5 Posted : Tuesday, September 17, 2013 6:36:32 PM(UTC)
HI
You can zip the file and attach to reply.
memphisjed
#6 Posted : Tuesday, September 17, 2013 6:59:26 PM(UTC)
memphisjed
select all, right click and change resolution. Circle looks good, the outer arc if part of a group will be group resolution. It will print and dimension nice even in course resolution.
NorthridgeFab
#7 Posted : Wednesday, September 18, 2013 4:50:38 PM(UTC)
NorthridgeFab
HI
Thanks, its attached
When I select all and right click it does not give me a change res option. I am using a mac if that matters.
reardtab.dxf.zip (20kb) downloaded 7 time(s).
blowlamp
#8 Posted : Thursday, September 19, 2013 3:19:46 AM(UTC)
blowlamp
It does look like a bug in ViaCAD as this file opens OK in all my other CAD/CAM programs.
However, if I save your file from any of my other programs, it then reads into ViaCAD as expected.
Which program did you use to create the drawing?
Martin.
NorthridgeFab
#9 Posted : Thursday, September 19, 2013 8:09:06 AM(UTC)
NorthridgeFab
Martin.
Thanks for checking it. I contacted Punch!, but they said they can't help with How-To, only tech problems. I see this a problem, not a how to.
It was drawn by a customer, so I'm not sure what program was used to create it.
#10 Posted : Thursday, September 19, 2013 11:26:58 AM(UTC)
Fixed in the 1094 code stream.
The dxf file contained a 2D polyline with lines and arcs. The ViaCAD polyline only supports lines and needed to account for this type.
NorthridgeFab
#11 Posted : Monday, September 23, 2013 9:02:05 AM(UTC)
NorthridgeFab
Can you elaborate on how you fixed this?
