2D Drafting
File not opening correctly (#4823)
When I open this DXF file in VC is does not show correctly. When opening in Draftsight, it shows correctly. VC is the white background.
NorthridgeFab attached the following image(s):
(7kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
Can you post the DXF file for us to look at? Martin.
I think your custom resolution is wrong. Try preferences and check your custom resolution. I have mines at super fine and curve angle 2.0
Adjusting the resolution did not fix it. How do I post the DXF?
HI You can zip the file and attach to reply. Regards Jason
Thanks: 35 times Was thanked: 15 time(s) in 13 post(s)
select all, right click and change resolution. Circle looks good, the outer arc if part of a group will be group resolution. It will print and dimension nice even in course resolution.
Originally Posted by: jdi000 HI You can zip the file and attach to reply. Regards Jason
Thanks, its attached
Originally Posted by: memphisjed select all, right click and change resolution. Circle looks good, the outer arc if part of a group will be group resolution. It will print and dimension nice even in course resolution.
When I select all and right click it does not give me a change res option. I am using a mac if that matters.
reardtab.dxf.zip
(20kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
It does look like a bug in ViaCAD as this file opens OK in all my other CAD/CAM programs. However, if I save your file from any of my other programs, it then reads into ViaCAD as expected. Which program did you use to create the drawing? Martin.
Originally Posted by: blowlamp It does look like a bug in ViaCAD as this file opens OK in all my other CAD/CAM programs. However, if I save your file from any of my other programs, it then reads into ViaCAD as expected. Which program did you use to create the drawing? Martin.
Thanks for checking it. I contacted Punch!, but they said they can't help with How-To, only tech problems. I see this a problem, not a how to.
It was drawn by a customer, so I'm not sure what program was used to create it.
Fixed in the 1094 code stream.
The dxf file contained a 2D polyline with lines and arcs. The ViaCAD polyline only supports lines and needed to account for this type.
(126kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: Tim Olson Fixed in the 1094 code stream. The dxf file contained a 2D polyline with lines and arcs. The ViaCAD polyline only supports lines and needed to account for this type. Tim
Can you elaborate on how you fixed this?
2D Drafting
