NorthridgeFab
#1 Posted : Saturday, May 11, 2013 3:46:21 PM(UTC)
NorthridgeFab
I am trying to draw this steel sheetmetal part that will be cut on a cnc table then bent. I have a drawing of the part that's attached. I need help getting it drawing flat. When it's bent it will create a channel, it is the vertical on flatbed headache rack.
Untitled 1.vc3 (6kb) downloaded 15 time(s).
memphisjed
#2 Posted : Monday, May 13, 2013 2:56:04 AM(UTC)
memphisjed
That is going to be an expensive piece of plate, going down to 1 inch would save a very big penny. Most shops can bend 1", but 2 inch takes a serious break (our 150 ton wimpers under 2"). Also 1 inch can be plasma cut with 260 machines, while 2" is torch only. Plasma is much cheaper.
To unfold a shape: draw a work path along the bend axis. ASTM 36 is close to 1/3 of the width on the inside of a bend. Have a fillet inside dimension from the break/press handy. (example uses 1/8"). Also take in account miters, extending the bend axis lines to square material. Add up all the lengths of the work path; your case has bottom, bend, and top. draw your base line, and then a line perpendicular with total work path length. draw top line, then your edges.
Simple, now repeat with multi-bends and complex shapes and your stomach will burn from coffee and aspirin.
bentplate.vcp (20kb) downloaded 15 time(s).
L. Banasky
#3 Posted : Monday, May 13, 2013 3:13:58 AM(UTC)
L. Banasky
I'm thinking it is a part made from 10 ga. or 12 ga. material. Sheetmetal was mentioned in the original post.
memphisjed
#4 Posted : Monday, May 13, 2013 6:18:54 PM(UTC)
memphisjed
then the original drawing is short a view. Not the first time, or last, I will mis-read a drawing. Unwrapping procedure stays the same.
NorthridgeFab
#5 Posted : Tuesday, May 14, 2013 8:21:02 AM(UTC)
NorthridgeFab
The piece is being bent from 12g. No, not all the views are there. Unwrapping it is what I am having trouble with.
memphisjed
#6 Posted : Tuesday, May 14, 2013 3:36:17 PM(UTC)
memphisjed
For roughing out an unwrap use paper, you can even check for exactness by printing a copy with the bend line section then cutting out with scissors or xacto. Paper is cheap and soft.
NorthridgeFab
#7 Posted : Wednesday, May 15, 2013 6:57:45 AM(UTC)
NorthridgeFab
I've dont that on smaller pieces, but this is rather large.
memphisjed
#8 Posted : Wednesday, May 15, 2013 11:43:06 AM(UTC)
memphisjed
print window has a scale function. print to numerical scale not paper size - this helps edits.
