kevjon
#1 Posted : Saturday, May 31, 2014 11:15:09 PM(UTC)
kevjon
Hi
I'm using Viacad 8 on Win7.
I have used the "loft surface tool" between two adjacent surfaces to get the whole blended together (purple section).
When I apply zebra analysis it looks fine but when I join the surfaces it looses continuity as show by the skewed zebra.
Is it a bug or am I doing something wrong ?
kevjon attached the following image(s):
4 Join Surface.jpg (69kb) downloaded 8 time(s).
#2 Posted : Sunday, June 1, 2014 11:56:27 PM(UTC)
Does it do this if you turn off healing in the join command?
Join: Options: Maximum Heal Gap Size=0.0.
Also, be sure to crank up your display resolution, the zebra normals are calculated at the display facet density.
kevjon
#3 Posted : Monday, June 2, 2014 2:56:17 AM(UTC)
kevjon
Hi Tim
Thanks for a reply.
When I set heal gap to 0.0 and change the resolution of the joined surfaces to super fine I still get stepping in the zebra which indicates to me there are problems with my continuity.
When I export to obj and bring it into modo, it renders Ok though, although I can see very minor flaws there.
See attached image.
5 Join Surface.JPG (87kb) downloaded 8 time(s).
#4 Posted : Monday, June 2, 2014 9:00:03 AM(UTC)
Can you post or private email me the file? tim.olson at evo-soft.net
kevjon
#5 Posted : Tuesday, June 3, 2014 1:53:28 AM(UTC)
kevjon
Ok, I've sent it off to you, let me know if you didn't receive it.
kevjon
#6 Posted : Wednesday, June 4, 2014 3:28:14 AM(UTC)
kevjon
Tim has responded via email. Great service !
His solution in this case was to Set both stitch gap and heal gap to 0.0 in the join surface command options which resulted in a prefect zebra after the join.
