klais
#1 Posted : Thursday, August 26, 2010 8:15:26 PM(UTC)
klais
Does anyone know if the Concepts Explorer has ever allowed group/series selection of features in the same manner as the Mac Finder or Windows Explorer (click -> shift + click to select end of series)? I am trying to work on a complex part with hundreds of features and manipulating them one at a time is super tedious.
Also, is there a way to highlight the features on the model as they are picked from Concepts Explorer.
Regards,
Kevin
NickB
#2 Posted : Friday, August 27, 2010 1:57:55 AM(UTC)
NickB
Kevin,
Unfortunatly the concept explorer will not let you select multiple parts or features simultaneously. Even more frustrating is that you can not see and control layers AND features simultaneously.
The only way that you can (semi-reliably) see where a feature is on a part as you select it in the feature list is to go change your view from shaded to wire frame.
Both of these areas need a lot of attention, and users have been asking for enhancments for years, and for years nothing has happened.
Shark FX 9 build 1143
OS X 9.5
matter.cc
