Any way to import an old .vlm file? (#3487)
I have some old .vlm files I'd like to import, so old I'm not sure what version they are from, I think 2.7. Like the subject says, any way to import them?
I use an old copy of Graphite to open those, then use batch convert to DXF or IGES. You can then drag and drop the IGES or DXF onto Shark or ViaCAD.
Shark FX 9 build 1143
OS X 9.5
matter.cc
Thanks: 199 times Was thanked: 164 time(s) in 113 post(s)
Vellum 2.7 still runs well on WinXP, if you want to post a few files I can convert them to your choice that Vellum 2.7 offers.
(102kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: jtfx I have some old .vlm files I'd like to import...
you may export to DXF/DWG if your ol' Vellum is still running...
...if not avail any more and only several ones, zip and email them and I'll return them as DWGs.
hth,
Norbert
Ashlar's free Graphite Share app works well for me, and will export to dxf/dwg (and others).
Graphite share worked, thats everyone for the suggestion!
