jb2953
#1 Posted : Wednesday, July 10, 2013 12:50:04 PM(UTC)
jb2953
I use model to sheet for 3d all the time it works great. I am trying to model to sheet a 2d drawing and all I get is a blank page. Am I missing a step somewhere?
Thanks Jim
chipmaker2
#2 Posted : Sunday, July 14, 2013 9:36:47 PM(UTC)
chipmaker2
Model to sheet is used for making views of 3D objects.
2D has no need of this feature.
Chuck
thanks 1 user thanked chipmaker2 for this useful post.
Jimbl on 3/1/2024(UTC)
#3 Posted : Sunday, July 14, 2013 9:49:25 PM(UTC)
Not really Chuck, Model to sheet should be able to handle to 2d objects to work with scalable sheets, example, you sketch a layout plan of a building in 2d, you need to print the sketch, so, this must be placed on a viewport that handle scales for blue prints and so.
Jim, unfortunately, on via cad-shark, if yo need to do put 2d objects (non solids or surfaces), you must copy them (and they must be ungrouped), and paste on a viewport made previously, thats the workaround that work for me when a need to do this, but it is kinda frustrating
Obviously, there is a fail on the software, must be a bug o non considered logic procedure of the workflow on the design.
Model to sheet is a great tool, but is widely discussed topic on the forum about its glitches and still considering amount of work to do to make a stable-really efficient tool as it should.
Mean while, yes, it is a great and must have tool.
Luis G-.
MacOSX Sequoia 15.7.7
thanks 1 user thanked lgrijalva for this useful post.
jb2953
#4 Posted : Monday, July 22, 2013 6:27:23 PM(UTC)
jb2953
You are right Luis, I first printed a template sheet , then I scaled the drawing and then printed the drawing on my previously printed template.
Jim
#5 Posted : Tuesday, July 23, 2013 10:53:21 AM(UTC)
>>Model to sheet should be able to handle to 2d objects to work with >>scalable sheets, example, you sketch a layout plan of a building in 2d, you >>need to print the sketch, so, this must be placed on a viewport that handle >>scales for blue prints and so.
Yes, MtoS should be able to create scalable sheets.
I recently fixed some issues in v9 regarding putting walls, doors and windows into MtoS. Be sure to have the "Ignore Curves" disabled in the MtoS dialog box.
jb2953
#6 Posted : Thursday, July 25, 2013 6:06:58 PM(UTC)
jb2953
Disable ignore curves. I now have a Model to sheet.
Jim
