jb2953
#1 Posted : Monday, March 18, 2013 6:23:33 PM(UTC)
jb2953
Can any tell why if I bisect a circle with a straight line and then use the trim tool the whole circle disappears? It seems to be hit and miss, sometimes the circle disappears sometimes only half disappears which is what I want to happen.
Thanks Jim
Tem
#2 Posted : Monday, March 18, 2013 6:25:56 PM(UTC)
Tem
Maybe, a surface that both intersects and lies outside the sphere could be used to trim the sphere into 2 hemispheres, of course deleting the par that you don't want.
rockyroad_us
#3 Posted : Tuesday, March 19, 2013 5:56:49 PM(UTC)
rockyroad_us
I'm guessing that you have the line or circle at a different Z level or depending which plane you drew it. The program normally prompts you.
jb2953
#4 Posted : Tuesday, March 19, 2013 6:38:57 PM(UTC)
jb2953
I started drawing everything from 2 points that were in the same plane. I think lines and circle are in the same plane. The reason I only want half a circle but most of the time when I try and draw an arc it doesn't want to lay flat on the plane it seems to be at an angle or upright.
Thanks Jim
rockyroad_us
#5 Posted : Tuesday, March 19, 2013 9:19:02 PM(UTC)
rockyroad_us
make sure you have work plane as snaps.
jb2953
#6 Posted : Wednesday, March 20, 2013 1:11:16 PM(UTC)
jb2953
Thanks Rockyroad
The snaps on the work plane did the trick
Jim
Tem
#7 Posted : Thursday, March 21, 2013 12:02:42 AM(UTC)
Tem
Yes above/behind the surface to intersect and cut.
Guest (10)
