3 Pages<123>
Stefan
#21 Posted : Saturday, January 5, 2008 12:52:26 PM(UTC)
Stefan
Hello Tim,
i just downloaded the ViaCAD Beta (Mac) and it gave me installation errors, while after that the Beta seems to run fine. However, when i start my original ViaCAD 711, it starts now with a registration screen, containing a new serial number and i cannot enter my offical 711 authorisation code again, because it does not allow me to change the (new) serial number in the input field!
What can i do to run my original software again?
Stefan
domcm
#22 Posted : Saturday, January 5, 2008 2:31:31 PM(UTC)
domcm
Same thing happened to me. I had to re-register and get another authorization code. Not sure if this is the easiest way, but it worked.
Stefan
#23 Posted : Saturday, January 5, 2008 3:05:12 PM(UTC)
Stefan
Yep, had to re-register my original also again.
Stefan
#24 Posted : Saturday, January 5, 2008 3:14:28 PM(UTC)
I downloaded and installed the beta at home and did not get an error message. Do you recall what the message was?
Stefan
#25 Posted : Saturday, January 5, 2008 3:51:49 PM(UTC)
Stefan
Sorry Tim, i don´t remember. It sayed something like that i should look into an error log, but i didn´t...,sorry!
o.k. i checked the error log:
Installation started on 2008-01-05 19:36:37 +0100
ViaCAD 2D:3D v5.0.2 Installer
"SketchUpReader.framework" at "/Library/Frameworks" was installed.
"SketchUp.framework" at "/Library/Frameworks" was installed.
"3DxUSBDriver.framework" at "/Library/Frameworks" was installed.
"ViaCAD 3D v5 Beta" at "/Applications" was installed.
"WkMacLibX.zip" at "/Library/Frameworks" is newer and was not replaced.
An error occurred executing script "mv.txt". Error = 256
Installation finished on 2008-01-05 19:37:32 +0100
Stefan
#26 Posted : Saturday, January 5, 2008 5:28:18 PM(UTC)
Stefan,
Thanks for the heads up. We made some changes to the registration code to support changes in Leopard. I fixed the beta such that this no longer happens and uploaded a new installer (same links as before).
BWTR
#27 Posted : Saturday, January 5, 2008 6:55:15 PM(UTC)
BWTR
How come that the ViaCAD Beta opened with my ViaCAD 711 screen layout and, when I changed things in the Beta, the original 711 version was changed ("Buggered up" to use a good Aussie expression!)?
#28 Posted : Saturday, January 5, 2008 11:16:34 PM(UTC)
Each user has their own perferences, stored outside the application. The preferences file is the same for 711 and 735.
BWTR
#29 Posted : Saturday, January 5, 2008 11:42:01 PM(UTC)
BWTR
I guess so is this?
Normal workings of Betas appreciated mate.
And, I gather we can still not lock off the 2D foul up of our UI if that is accidentaly clicked ,either still?
BWTR attached the following image(s):
#30 Posted : Sunday, January 6, 2008 2:28:58 PM(UTC)
The registration info getting removed is now fixed. I uploaded a new ViaCAD 2D/3D installer with the correction yesterday. It uses the same link as before.
BWTR
#31 Posted : Sunday, January 6, 2008 7:45:19 PM(UTC)
BWTR
Thanks Tim.
BWTR
#32 Posted : Sunday, January 6, 2008 8:51:05 PM(UTC)
BWTR
Sorry mate!
It's STILL f------Up!
Not happy.----having deleted the Beta I can not make my Owned copy legal!
#33 Posted : Sunday, January 6, 2008 11:15:44 PM(UTC)
You need to re-register the app. Launch the program, fill in your name, company, and hit register to receive a new auth code. Your old auth code will not work with the new serial number. The new mac beta corrects the problem of trashing the 711 registration info.
BWTR
#34 Posted : Tuesday, January 8, 2008 12:54:29 AM(UTC)
BWTR
Tim, I am still a bit confused. I went through that exercise and re-established my ownership of the 711 version with the the new authorisation code.
If I download the Beta, again, will I still have to go through this exercise? Again!
I won't waste my time if so.
#35 Posted : Tuesday, January 8, 2008 1:38:52 AM(UTC)
I fixed the mac beta and uploaded. Working on getting an update to the windows beta. Will holler back when the windows beta has this corrected.
#36 Posted : Tuesday, January 8, 2008 4:57:10 PM(UTC)
ViaCAD 2D/3D PC is now updated regarding the messing around with the older installs registration info. Use the same links as before to download the updated beta.
BWTR
#37 Posted : Tuesday, January 8, 2008 6:44:01 PM(UTC)
BWTR
Thanks--fingers crossed!
Brian
BWTR
#38 Posted : Wednesday, January 9, 2008 2:06:05 AM(UTC)
BWTR
This is what my OWNED copy of ViaCAD looks like.
And the BETA looks exactly the same, including pinching my owned copy UI set up.
VERY not amused!
#39 Posted : Wednesday, January 9, 2008 10:59:41 AM(UTC)
I'm not sure I understand what is wrong.
posh.de
#40 Posted : Wednesday, January 9, 2008 12:05:46 PM(UTC)
posh.de
probably the "Not for Resale" in the splash/about screen.
Norbert
Guest (22)
3 Pages<123>
