42 Pages«<1213141516>»
Solid Modeling
New Posts Help undo shell command
shell reverse undo delete remove
Morphin , 6/7/2016 3:38:15 PM(UTC)
4 9,039 Morphin Go to last post Go to first unread
6/8/2016 5:43:36 AM(UTC)
New Posts Positioning objects along an axis
Logicursor?
matso , 5/9/2016 7:50:07 AM(UTC)
13 21,177 matso Go to last post Go to first unread
6/7/2016 10:09:24 AM(UTC)
New Posts Blend issue
flatpack , 5/27/2016 10:52:16 AM(UTC)
3 7,227 flatpack Go to last post Go to first unread
5/27/2016 1:51:46 PM(UTC)
New Posts How to get curves from one side of solid?
macnavi , 5/21/2016 12:23:21 PM(UTC)
4 10,234 macnavi Go to last post Go to first unread
5/22/2016 9:58:10 AM(UTC)
New Posts How to put a weld easily
magicart , 5/1/2016 6:01:17 AM(UTC)
8 14,524 magicart Go to last post Go to first unread
5/9/2016 1:51:24 PM(UTC)
New Posts Multiline tool does not create closed solid, all lines are separate
Can't seem to create a closed outline to extrude
Wyattsdad , 5/7/2016 7:23:25 PM(UTC)
1 5,233 24c Go to last post Go to first unread
5/8/2016 1:37:27 AM(UTC)
New Posts How to split solid
macnavi , 4/14/2016 4:37:44 AM(UTC)
11 19,018 flatpack Go to last post Go to first unread
4/14/2016 3:02:45 PM(UTC)
New Posts Modeling and rendering a wire mesh
G2Art , 4/11/2016 11:46:13 AM(UTC)
14 26,881 Antoine Go to last post Go to first unread
4/13/2016 6:27:33 AM(UTC)
New Posts Wrapping a curve fully (360 deg) around a cylinder
G2Art , 4/6/2016 3:45:29 PM(UTC)
9 14,956 Tim Olson Go to last post Go to first unread
4/7/2016 4:10:26 PM(UTC)
New Posts Cannot replace profile in extruded solids
After I select the first curve the process comes to an abrupt stop
G2Art , 4/6/2016 10:06:09 AM(UTC)
0 4,213 G2Art Go to last post Go to first unread
New Posts Creating Apertures 2D/3D module
Creating additional apertures in 2D drawing once created a 3D solid
Tony , 3/27/2016 1:56:41 PM(UTC)
2 6,200 rokoko Go to last post Go to first unread
3/28/2016 7:20:24 AM(UTC)
New Posts 3D Modeling - Extrusion Error
Message 'Curves Not Planar' on Extrusion - Unable to find issue
RustyL , 3/20/2016 6:03:51 PM(UTC)
3 7,492 Claus Go to last post Go to first unread
3/21/2016 6:17:32 AM(UTC)
New Posts more unexpected behaviour...
ianjkirby , 3/15/2016 7:52:21 PM(UTC)
0 3,910 ianjkirby Go to last post Go to first unread
New Posts unexpected behaviour...
ianjkirby , 3/15/2016 5:10:25 PM(UTC)
0 4,362 ianjkirby Go to last post Go to first unread
New Posts Subtracting solid error
Trying to subtract the pickups and neck route from a carve top guitar
neotericsimian , 3/13/2016 4:38:06 PM(UTC)
2 6,715 neotericsimian Go to last post Go to first unread
3/13/2016 9:43:34 PM(UTC)
Guest (279)
