42 Pages«<1011121314>»
Solid Modeling
New Posts Cant remove a Edge?
3dup , 3/11/2017 8:44:24 AM(UTC)
3 8,123 jdi000 Go to last post Go to first unread
3/11/2017 10:15:44 AM(UTC)
New Posts Constant Wall Thickness for Complex Sheets
Needed for injection molding plastics
PRP , 2/10/2017 6:37:44 PM(UTC)
9 16,444 PRP Go to last post Go to first unread
3/7/2017 3:23:41 PM(UTC)
New Posts Trim solid at an angle
Trim solid at an angle in the Z plane
mcaliebe , 3/2/2017 8:09:04 PM(UTC)
5 12,105 horst.w Go to last post Go to first unread
3/3/2017 10:14:48 AM(UTC)
New Posts Lathe Solid Problem
ipc1-de , 2/21/2017 11:14:25 AM(UTC)
12 19,974 Tim Olson Go to last post Go to first unread
2/24/2017 11:00:49 AM(UTC)
New Posts 3D Model Editing (Shark LT)
evakyl40 , 2/17/2017 5:21:26 AM(UTC)
4 10,426 horst.w Go to last post Go to first unread
2/18/2017 1:38:24 PM(UTC)
New Posts impossible skin
Antoine , 2/7/2017 4:39:06 AM(UTC)
4 10,387 Antoine Go to last post Go to first unread
2/14/2017 2:58:15 AM(UTC)
New Posts Merge by cut objects?
Cutting solids and bring it together
ipc1-de , 2/11/2017 10:09:22 AM(UTC)
6 11,081 horst.w Go to last post Go to first unread
2/12/2017 2:53:30 PM(UTC)
New Posts "Blend" question
Art Smith , 2/10/2017 2:47:43 PM(UTC)
4 9,419 Art Smith Go to last post Go to first unread
2/11/2017 7:49:42 AM(UTC)
New Posts FINDING GAPS
joining curves to create surface to extrude
[+2]
Guest , 1/7/2017 11:34:36 PM(UTC)
5 11,699 MaiFy Go to last post Go to first unread
2/10/2017 4:25:02 PM(UTC)
New Posts Simple way to convert STL to solid
macnavi , 7/22/2016 5:53:01 PM(UTC)
8 21,165 Tim Olson Go to last post Go to first unread
1/30/2017 1:42:24 PM(UTC)
New Posts Polygone moves away
horst.w , 1/24/2017 3:50:45 PM(UTC)
3 8,342 horst.w Go to last post Go to first unread
1/25/2017 3:22:22 AM(UTC)
New Posts Smart Silhouette
Can't select smart silhouette
mitchb , 1/11/2017 8:59:44 PM(UTC)
0 5,145 mitchb Go to last post Go to first unread
New Posts Push/Pull Distance Exact # Entry
bbumgarner , 12/27/2016 2:35:38 PM(UTC)
7 13,858 macnavi Go to last post Go to first unread
1/1/2017 7:46:21 PM(UTC)
New Posts Can't place hole on opposite side.
L. Banasky , 12/20/2016 10:28:22 AM(UTC)
3 9,292 murray Go to last post Go to first unread
12/20/2016 10:50:58 PM(UTC)
New Posts WorkPlane alignment with arbitrary infinite plane ???
Art Smith , 11/21/2016 1:28:34 PM(UTC)
3 8,924 Art Smith Go to last post Go to first unread
11/21/2016 2:27:19 PM(UTC)
Guest (170)
